Interactive table & UGS
we are prepairing a conference and i have an idea to make a presentation about reverse engineering on a interactive board or smartboard
Has someone done that before? how is the compatibility with NX.
Maybe some video links..
RE: Interactive table & UGS
It has been a while but I have used a “Smart Board” with NX. The only problem I encountered is these are typically used with Power Point so the workstation may not have the processor to run NX very well. You may need to connect the smart board to an engineering workstation. There may be some drivers needed for the mouse and board. Other than that the interaction was very good.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6, NX7.5,NX8.5, NX9.0
Vericut7.3
do all boards have ability to conect to a pc or laptop?
wich board have you been using...?
thanks
