maximum spacing of lap splice bars in tension
Hi ,
I am doing a design of pile cap with single pile, in which the pile bars and the vertical reinforcement are spaced 150 mm center to center.
But the pile tolerance is 75 mm which sometimes makes the vertical bar of pile cap and pile bar in pile to 225 mm.
Can anyone suggest the maximum spacing between the pile reinforcing bar and pile cap vertical reinforcement.
http://files.engineering.com/getfile.aspx?folder=8...
Please give your valuable suggestion.
RE: maximum spacing of lap splice bars in tension
Usually, I'll assume a perfectly vertical strut running from the center of the column base plate down to the top of the pile. That will induce a moment in the pile which is generally pretty easy to deal with. With this scheme, your pile cap reinforcement doesn't really do anything other than provide some extra confinement. I'm assuming that your only significant load here is downward load.
Another design model is to assume that the moment is resolved in the pile to cap connection. In that case, your best bet is as strut and tie analysis and whatever reinforcing layout stems from that.
My concern is if the pile has an offset and the pile cap is in tension , the vertical bars in the pile cap is subjected to tension ,
How the tension force from the pile cap bars is transferd to the pile reinforcemnt . Can conrete be in tension to transfer the force from pile cap reinforcemnt to pile reinforcemnt .
This is my major concern ?
What i would do in this case ,
Is there any new solution for this .
It would be helpful if you posted sections of the pile and the cap so that we can see the arrangement of the vertical bars. Unfortunately, if you are unable to install horizontal tie bars, you don't have a whole lot of options for resisting serious tension.
See the sketches that I posted in this thread to get a feel for the mechanics of the situation and what needs to happen with regard to horizontal reinforcing: http://www.eng-tips.com/viewthread.cfm?qid=374061. You have a similar situation at both the top and bottom of your cap.
