'Restart' msc Marc
'Restart' msc Marc
Although the second anaysis starts from the end of the first(as it should),it still uses the bountary contitions from the first one.
I created a very simple problem:one cantilever with a fixed displacement at the end.The fisrts analysis has a displacement opposite the y direction(-10) and the second has a possitive displacement(+20).I use the restart command and write a .t8* file (multi increments file) and the second analysis reads this file.The result it give me is a displacement -20,in other words it runs the 1st analysis 2times.
