multiply arrangement combination in NX 8.5 and latter, possible or not?
I have small problem with arrangement. It is done in NX 8.5 as customer have that version. I made an assembly that have too much option for my taste, and all of them have to be easy controlled. Easy control with arrangements is now working but I would like to make it simple as possible so I am looking for a way to make less arrangement but to be able to combine them in assembly. Is that possible? Main issue is that I need some of arrangements to be equation driven and some to be user selected... Is there a way to do it? No matter arrangements or not... any suggestions?
RE: multiply arrangement combination in NX 8.5 and latter, possible or not?
You might consider Product Template Studio here.
With PTS you can choose which arrangements are displayed as options for the user (out of all possible arrangements) and you can create UI to drive any expression-driven and/or equation-driven assembly changes necessary (suppression of components by expression, use of Visual Rules to add/remove/replace assemblies as needed.)
Lots of options here for creating exactly the UI you want for complex models.
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Product Engineering Software
Siemens Product Lifecycle Management Software Inc.
(Phoenix, Arizona)
So you already know about the PTS control for displaying only selected arrangements, then?
Taylor Anderson
(Phoenix, Arizona)
