Disappearing Constraints Dialog
I've unclipped the constraints dialog within the sketching editor and now I can't find it. When I click on the constraints button it flashes briefly and then the dialog is hidden somewhere. I can't seem to find it. Please help. I am unfamiliar with the dialog settings. I am using NX7.5. Thank you
RE: Disappearing Constraints Dialog
First, are you running with dual-monitors? If so, the dialog may have ended-up on the other screen.
Irrespective of that, try going to...
Preferences -> User Interface -> Layout
...and in the section of the dialog labeled 'Settings', push the 'Reset Windows Position' icon.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you John. I've got it working somewhat. The dialog appears when I click on an object I want to apply a constraint and then the dialog pops up. It's just a weird behavior.
