Surface tangent to another surface
RE: Surface tangent to another surface
The attached example shows a Surface 'Through Curves' where the first Section is tangent to the gray surface whereas the second Section is simply connected to the orange surface. If you edit the green surface you'll see how it was created.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hello John,
Thanks for your prompt reply.
That's not actually what I'm looking for. Sorry I didn't explain my request clearly
Please see the attached picture
Isocline and Silhouette Curves does not create what I need.
The surface needs to be connected to the curved surface along it tangentially as sort of indicated in the picture.
Ian
Ok, here's a solution using the 'Section Surface' function with the Type set to 'Linear'. You can see what other settings I used by simply editing the Green surface.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hello John,
That's what I was looking for.
Many thanks.
Ian
