Bridging the wood-steel gap
I'm looking for everyone's thoughts on subjecting engineered lumber to exterior exposure. On more than a few occasions now I've encountered situations where conventionally available dimensional lumber (<= ~3-ply 2x12) is not structurally adequate in an exterior exposure setting. LVL, PSL and Glu-Lam's aren't typically rated for exterior exposure, and even when they are I've heard that their resistance to exterior conditions is similar to exterior rated plywood, i.e. that its good for short-term exposure during construction but needs to be completely protected in the long run. I've seen my fair share of poorly/improperly spec'd PSL and LVL beams that soaked up moisture like a sponge and lost over 50% of their cross-sectional area in just a few years.
Most residential and small-time commercial contractors shriek when the dreaded "steel" word comes up, so in the past I've given the contractor preliminary engineered lumber beam sizes and recommend that they look into engineered beams that the manufacturer will back up as rated for continuous exterior exposure. Without fail the contractor returns to say either, "they aren't available", or, "they're so expensive lets just use steel".
What does everyone else do? Flitch beams aren't very structurally efficient, and they're labor-intensive and costly on the engineering/detailing side of the coin. Heavy, solid sawn timber beams are expensive and have long lead times, at least in this area. It's easy from our end to just spec steel and be done with it, but most of these project's budgets can't afford more than a semi-skilled carpenter with a chop saw. Anyone know anything about engineered lumber beams with continuous exterior exposure rating? Do they even exist? Does anyone have any other reasonable alternatives for these situations?
RE: Bridging the wood-steel gap
You might want to call Boise Cascade to see what they recommend and what might be available in your area. I find that most of the contractors you are talking about are resistant to change and might be scared by what is a minor specification.
PT Glulam. Strong, cheaper than PSL.
http://www.anthonyforest.com/treatedbeams.shtml
When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.
-R. Buckminster Fuller
Mike McCann, PE, SE (WA)
Otherwise, definitely check with Scotty on the transparent aluminum.
@ XR250 / manstrom / TLHS
I have seen countless pavilion structures with glu-lam frames but didn't know that the exterior rated beams were commonly available. I have since found a somewhat local manufacturer that supplies our area.
@ BUGGAR
This specific project isn't new construction, its repair and rehab of several large occupied apartment buildings. There is no forklift or wheeled equipment access, and any work that starts at 9AM must be finished by 4PM. The install crew is already onsite and they are all carpenters. So steel really isn't feasible.
@msquared48
I really wanted to poke fun and make some Star Trek references, but then a quick web search showed me that transparent aluminum now actually exists. Actually, its transparent alumina and not aluminum...
Wow, transparent aluminum
@ mike20793 / Splitrings
We're hesitant to specify PSL or LVL, even if they are manufacturer or installer treated. This specific project is to replace 8 year old PSL and LVL beams that we could scrape away ~75% of cross-sectional area with our fingernails. We're not in a marine environment here, but we are in the worst area otherwise for decay potential according to AWPA (see map in the attachment). Vermont is in the "Moderate" decay potential area, while we are in the "Severe" area.
You’ve answered your own question on the wood vs. steel issue. Give them a choice and they quickly come around. Carpenters do know how to use a nut-n-bolt and a socket wrench when they have to. Detail the steel cleanly and have the fab. shop punch flg. and web holes, when and where needed to pad the stl. beam out, when that’s needed. They can do it when they have to, or when it costs less to accomplish what you want, they just don’t do it every day. Minimize the steel work they have to do and keep the pieces fairly light, and they are usually o.k.
I am quite sure that you can get treated GlueLams, but they aren’t an off-the-shelf item, or even made by every GlueLam fab. shop. I also believe a few suppliers have done some work of preservative treated LVL’s and PSL’s, etc.. And, I suspect they don’t take treating very well because of the glue, and there are thousands of surface cells and fibers which tend to suck up moisture and causes them to swell and go to hell. One important detail on exterior wooden beams, and built-up members (post tops too) is to flash the beam tops with peal-n-stick tape or even ice-n-water guard self sticking/self healing rolled goods. Cut it so .5" to .75" hangs over each side of the beam, and bend it over a bit, but don’t stick it down tight to the side. Rather let it hang down so it acts as a drip edge on the top of the beam. Do this on deck joists and multi-ply 2x beams too, keep the water off the tops and out of the plys, where it tends to never dry out. Watch out for some of today’s treatments and hardware corrosion.
