Underlying element X instance Y can only have spos or sneg as a face identifier - heat transfer
Dear all,
I have created a part consisting of 2 perpendicular shell surfaces. I partitioned the part using datum plane (through both cells).
I want to use the part in a heat transfer analysis. When submitting the job I get the error
I was looking for the elements that were assigned this error and they are positioned along one of the edges that is partitioning the part and only on one side of the partitioning edge. It is curious that only elements belonging to the extruded surface are included in the error set.
Is there a way to fix this error?
Thank you
Best regards,
Thank you
Best regards,
RE: Underlying element X instance Y can only have spos or sneg as a face identifier - heat transfer
