FOS for overturning, retaining wall.
I need a second opinion on the method of calculating FOS for a gravity retaining wall. This is a port quay wall structure (water retaining, so high water table).
When calculating the FOS (restoring/overturning), I get significantly different results depending on how I sum the forces.
If I use an effective unit weights, i.e. bulk above water line and bulk minus water weight below, I get very different results as opposed to using full bulk unit weights and a buoyant overturning force to counteract this.
Basically:
EQ1: FOS = effective unit weights / overturning forces with no buoyancy.
EQ2: FOS = bulk unit weights / overturning forces including a buoyancy acting at the base
Hopefully this make sense, what are your thoughts? At the end of the day the differential between overturning and restoring is the same, but because for EQ2, you have higher numbers on top, and on bottom, you get a much smaller FOS.
Basically:
RE: FOS for overturning, retaining wall.
I eventually decided that #2 was the rigorously correct way of calculating overturning -- as it better accounts for the external forces acting on your structure -- although I suspect that some engineers may not consider the difference, and that probably eats into the typical 1.5 FS from time to time.
