Unable to locate Cloning in NX8
I am unable to Clone a assembly in NX8. It is not showing up under Assemblies when I have a assembly loaded.
My main task in to create a zip file of a large assembly. I have downloaded UGZIP from this site but yet to load it. I was thinking cloning would be faster way.
ET
ET
RE: Unable to locate Cloning in NX8
Assemblies -> Cloning -> Create Clone Assembly...
And if you can't find it, try using a Role with 'Full Menus'. But even it you hadn't you could have still found it by simply using the 'Command Finder' and entering the term "clone".
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
UGZIP uses the clone function then zips up the resulting files. As long as you get UGZIP set up properly, it should be just as fast or faster than doing it manually.
www.nxjournaling.com
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for the help!
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
