Special text characters - NX 8.5
If you have a line of text, how do you create a circle around a letter or number within that line of text? This is in NX 8.5.
RE: Special text characters - NX 8.5
Can you give an example of what you are trying to accomplish?
Ronald van den Broek
Application Expert
Wartsila Switzerland Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
How do you put a circle around the numbers 9 and 10?
http://www.myfonts.com/fonts/mti/circle-frame/
That being said, if this is not something that needs to fully associative you could simple leave an extra space before and after the numbers that you want circled and then create another note using the Drafting Symbol for a 'Sphere' set at twice the font size of the note and simply place them over the numbers, as seen below:
Another approach would be leave the numbers out of the text string altogether but including enough blank spaces so that you could later place a couple of ID 'Balloons', with the desired numbers, in the gaps.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
So, in many applications (including NX, I think), you can type 2473 and then press Alt+X, and you'll get a circled number 20. If that doesn't work, try copy/paste from the Windows Character Map app.
