SolidWorks from File Explorer
When I right clicked in Windows Explorer, there used to be a SolidWorks menu, with copy and rename features. Now, it is gone. We have recently upgraded from Windows XP to Windows 7, I think. Otherwise, I am not sure what we might have done.
This was a useful feature. Is there any way I can get it back?
JHG
RE: SolidWorks from File Explorer
Link
Link
Chris, CSWA
SolidWorks 14
SolidWorks Legion
I want to create new drawings and models by renaming existing ones that have in-context features. Our CAD management makes this difficult.
I am trying to remember the last time I used the feature. It may have been prior to our OS upgrade. The new Windows Explorer looks simplified compared to the old one.
JHG
Solution Id:
S-062845
Question:
After installing SolidWorks 2013, why is the SolidWorks menu (Pack and Go, Replace, Rename) not visible when right mouse button clicking on SolidWorks documents in Windows® Explorer?
Answer:
It is possible that the file association of the SolidWorks files has changed to SolidWorks 2013 (sldworks.exe of SolidWorks 2013).
Since SolidWorks 2013 SP0 onwards a new application is launched that is a SolidWorks launcher. Please refer to S-060464 for more information.
To correct the behavior change the file association of the SolidWorks file to 'SolidWorks Launcher'. To do so:
1) Open SolidWorks > go to Tools > Options > System options > File Explorer > click ‘Restore File Associations’ > ok > reconfirm behavior
2) If the point does not help then perform a similar operation manually; Go to the Control panel > Default Programs > Set Associations > .sldprt > Change program > select 'SolidWorks Launcher'. Perform same operation for .sldasm and .slddrw.
Hope that helps,
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesGryphon Environmental
www.2gryphon.com
www.scottjbaugh.com
Thank you. Actually, it looks like I was not actually clicking on The SolidWorks files. When I select one, the menu comes up. Problem between keyboard and office chair. :(
JHG
