Dohc and flat plane crank for Chev small block??????
I want to convert a small block chev to DOHC and put a flat plane crankshaft in it if possible. Does anyone know if LT5 heads (overhead cam) bolts onto 4-bolt-main small block chevy block? And know who to ask, where to go, who to talk to that knows about converting a small block chevy to a flat plane crank.
Thanx
Thanx
RE: Dohc and flat plane crank for Chev small block??????
Why do you want a flat plane crank?
I can't see what you gain
