Protecting Network Transformers
How are mesh and spot network transformers normally protected? I am very confused.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Protecting Network Transformers
In so far this is the setup: Units have a network protector on the low side, however the high side only comes with a 3 position disconnect mounted to the back of the unit: closed, open and ground. The plans call for having the MV disconnect supply tap directly into EPR feeder cable from the supply substation breaker which also supplies a dozen other transformers around the network in different vaults. The same holds true for other feeders in service.
"Throughout space there is energy. Is this energy static or kinetic! If static our hopes are in vain; if kinetic ù and this we know it is, for certain ù then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature". û Nikola Tesla
