There is no Cable tray subfolder under Electrical folder of Design library
I am new for Electrical routing, I found that in the design library, under the electrical folder , there is no cable tray subfolder.
Where can I load it ?
Thanks.
Thanks.
RE: There is no Cable tray subfolder under Electrical folder of Design library
You should call your VAR about this as well they will be able to help you a lot faster getting to know electrical within SW.
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesGryphon Environmental
www.2gryphon.com
www.scottjbaugh.com
