Fillet weld channel to bottom of W-shape?
Is it acceptable to fillet weld a channel to the bottom of a W-shape? I'd like to weld all sides of a C6 to the bottom of a W8 to support some lightweight pipes but table J2-5 of AISC 325 doesn't show an option for a fillet weld loaded normal to the axis of the weld.
RE: Fillet weld channel to bottom of W-shape?
I should add that the channel will be pointing normal (straight downward) from the W8 (horizontal)
Are you trying to increase the section modulus of the W8, or is this just for attaching the piping?
Mike McCann, PE, SE (WA)
Channel perpendicular to beam right? I think that you'll be fine. I'd be inclined to assume that most of the load transfer occurs near the beam web.
msquared48: This is only to attach piping running horizontally below the W8
KootK: In cross section it looks like this:
I
so I imagine you're right that most of the force is transferred into the beam web
