CHANGE SKETCH SUPPORT
Hello
I would like to know if is it posible to change the support of a sketch once it has been made.
I mean, for example, I have made an extrude through a sketch supported in a lateral face but unfortunately I was wrong
and I must change the support of this sketch...
Is there any way to change its support?
Thanks in advance for the suppport¡
RE: CHANGE SKETCH SUPPORT
What do you mean by "the support of a sketch"? If you mean, can I change the 'plane' that a sketch was drawn on, the answer is yes. When in the sketch editor, there is an option named 'Reattach' which will allow you select a new plane to attach the sketch to, but please keep in mind that the plane, either a Datum Plane or the planar face of a solid body, must be part of a feature that appears in the Part Navigator's 'Model History' section AHEAD of the sketch in timestamp order.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
