Torque due to piston effect and spring load
All,
I am just looking through a document with break out torque calculation for a ball valve and was wondering if anyone out there could explain these calculation:
Torque due to piston effect and torque du to spring load; see attached file for calculations.
http://files.engineering.com/getfile.aspx?folder=8...
I am used to a factor of perhaps 1/1000 for the piston effect; (1/1000)*R*E*u, where R = average sealing radius, E = piston effect and u = seat to ball friction coefficient and (2/1000)*R*E*u for the spring load.
It would be great if any of you clever folks out there could explain all the fancy math for deriving the torques in a layman's term for me :)
SubseaEng7
SubseaEng7
RE: Torque due to piston effect and spring load
Integral mentioned in calculation is giving syntax error. May be you can share the entire calcultion sheet?
Cheers!!!
The attaced file is all there is, but when calculating the integral I godt 4.2.
SubseaEng7
2A=Dc so ans of that integral is 2.2.
Didn't understand why did you calculated ball thrust as its value doesn't included in any formula.
Coefficient of Friction is 0.2 for which material?
