VUSDFLD subroutine for storing charLength
Dear all,
I have a problem with the VUSDFLD subroutine. The purpose is very simple: to store both triaxiality and characteristic length to use them as field variables for a damage model.
The subroutine works well for the triaxiality ratio, which is calculated from the stress tensor (see attached file). However, the subroutine does not work when I try to store the characteristic length (charLength). Just add a line as follows: Lchar = charLength(k) and the analysis is aborted. What is wrong with this?
I attach the vusdfld field. Many thanks in advance!
Kind regards,
Julio
Kind regards,
Julio
RE: VUSDFLD subroutine for storing charLength
By default Abaqus use implicit declaration of variables for FORTRAN subroutines.
Variables started with a-h and o-z are real and others are integers.
charLength array is real since it starts with x letter.
Lchar is integer since it starts with L.
You cannot assign real value for integer variable.
Change name from Lchar to charL and it should help.
Bartosz
Bartosz, thank you very much for your help.
Best regards,
Julio
