Journal: problem with deleted body
Hey,
For find solid body in part I use:
and it works fine.
But I have part with Delete Body function.
In Part Navigator Window I have only one body, but Vb sees two bodies, and one of then is no solid and no sheet body.
And can't add fantom body to solidbodies()
I don't know what I must doing for eliminate deleted body.
Maybe somebody can help me.
Best regards
Michał Nowak
NX9 & Tc10
CODE --> vb
Dim bodies As BodyCollection = workpart.Bodies
Dim solidBodies(0) As NXObject
Dim counter as Integer = 0
if bodies.ToArray.Length > 0 then
For Each thisBody As Body In bodies
If thisBody.IsSheetBody.Equals(False) Then
solidbodies(counter)=(thisBody)
counter += 1
End If
Next
End If But I have part with Delete Body function.
Best regards
Michał Nowak
NX9 & Tc10
RE: Journal: problem with deleted body
CODE
Option Strict Off Imports System Imports System.Collections.Generic Imports NXOpen Imports NXOpen.UF Module Module27 Sub Main() Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Dim displayPart As Part = theSession.Parts.Display Dim ufs As UFSession = UFSession.GetUFSession() Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Dim solidBodies As New List(Of Body) For Each theBody As Body In workPart.Bodies 'lw.WriteLine("IsSheetBody: " & theBody.IsSheetBody.ToString) 'lw.WriteLine("IsSolidBody: " & theBody.IsSolidBody.ToString) If theBody.IsSolidBody Then solidBodies.Add(theBody) End If Next For Each theFeature As Features.Feature In workPart.Features If TypeOf (theFeature) Is NXOpen.Features.DeleteBody Then Dim delBodyFeat As Features.DeleteBody = theFeature Dim delBodies() As Body = delBodyFeat.GetBodies For Each delBody As Body In delBodies If solidBodies.Contains(delBody) Then solidBodies.Remove(delBody) End If Next End If Next lw.WriteLine("work part contains: " & solidBodies.Count.ToString & " solid bodies that have not been deleted") End Sub End Modulewww.nxjournaling.com
it works great.
But I have another problem with user form and selection functions.
I wrote small program for show this:
CODE --> vb
Option Strict Off Imports System Imports System.IO Imports System.Collections.Generic Imports NXOpen Imports NXOpen.Features Imports NXOpenUI Imports NXOpen.UF Imports NXOpen.Utilities Imports System.Math Imports System.Windows.Forms Imports System.Collections Module Module1 Public ufs As UFSession = UFSession.GetUFSession() Public theUI As UI = UI.GetUI Public theSession As Session = Session.GetSession() Public workPart As Part = theSession.Parts.Work Public displayPart As Part = theSession.Parts.Display Public lw As ListingWindow = theSession.ListingWindow Public myBodies() As NXObject Public myBody As NXOpen.Body Sub Main() Dim myDialog As New Form1 myDialog.ShowDialog() End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination End Function Function SBody(ByVal prompt As String, ByRef selObj As NXObject) As Selection.Response 'funkcja pobiera body wkazane przez użytkownika Dim title As String = "Selection" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim cursor As Point3d Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart Dim selectionMask_array(1) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_component_type .Subtype = UFConstants.UF_component_subtype .SolidBodySubtype = 0 End With With selectionMask_array(1) .Type = UFConstants.UF_solid_type .Subtype = 0 .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, selObj, cursor) If resp = Selection.Response.ObjectSelected OrElse _ resp = Selection.Response.ObjectSelectedByName Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Function Bodies(ByVal prompt As String, ByRef selObj() As NXObject) As Selection.Response Dim theUI As UI = UI.GetUI Dim title As String = "Selection" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart Dim selectionMask_array(1) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_component_type .Subtype = UFConstants.UF_component_subtype .SolidBodySubtype = 0 End With With selectionMask_array(1) .Type = UFConstants.UF_solid_type .Subtype = 0 .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt, title, scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, selObj) If resp = Selection.Response.Ok Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function End Module Public Class Form1 Private Sub Button_OK_Click(sender As Object, e As EventArgs) Handles Button_OK.Click Me.DialogResult = System.Windows.Forms.DialogResult.OK Me.Close() End Sub Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button_Cancel.Click Me.DialogResult = System.Windows.Forms.DialogResult.Cancel Me.Close() End Sub Private Sub SelectBodies_Click(sender As Object, e As EventArgs) Handles SelectBodies.Click Me.Hide() If Bodies("Wskaż zwierciadla", myBodies) = Selection.Response.Cancel Then Exit Sub End If Me.Show() End Sub Private Sub SelectBody_Click(sender As Object, e As EventArgs) Handles SelectBody.Click Me.Hide() If SBody("Wskaż swiatłowód", myBody) = Selection.Response.Cancel Then Exit Sub End If Me.Show() End Sub End Class <Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _ Partial Class Form1 Inherits System.Windows.Forms.Form 'Form overrides dispose to clean up the component list. <System.Diagnostics.DebuggerNonUserCode()> _ Protected Overrides Sub Dispose(ByVal disposing As Boolean) Try If disposing AndAlso components IsNot Nothing Then components.Dispose() End If Finally MyBase.Dispose(disposing) End Try End Sub 'Required by the Windows Form Designer Private components As System.ComponentModel.IContainer 'NOTE: The following procedure is required by the Windows Form Designer 'It can be modified using the Windows Form Designer. 'Do not modify it using the code editor. <System.Diagnostics.DebuggerStepThrough()> _ Private Sub InitializeComponent() Me.components = New System.ComponentModel.Container() Me.Timer1 = New System.Windows.Forms.Timer(Me.components) Me.Button_Cancel = New System.Windows.Forms.Button() Me.Button_OK = New System.Windows.Forms.Button() Me.SelectBody = New System.Windows.Forms.Button() Me.SelectBodies = New System.Windows.Forms.Button() Me.SuspendLayout() ' 'Button_Cancel ' Me.Button_Cancel.Location = New System.Drawing.Point(25, 133) Me.Button_Cancel.Name = "Button_Cancel" Me.Button_Cancel.Size = New System.Drawing.Size(100, 42) Me.Button_Cancel.TabIndex = 8 Me.Button_Cancel.Text = "Cancel" Me.Button_Cancel.UseVisualStyleBackColor = True ' 'Button_OK ' Me.Button_OK.Location = New System.Drawing.Point(193, 133) Me.Button_OK.Name = "Button_OK" Me.Button_OK.Size = New System.Drawing.Size(114, 42) Me.Button_OK.TabIndex = 7 Me.Button_OK.Text = "OK" Me.Button_OK.UseVisualStyleBackColor = True ' 'SelectBody ' Me.SelectBody.Location = New System.Drawing.Point(25, 40) Me.SelectBody.Name = "SelectBody" Me.SelectBody.Size = New System.Drawing.Size(100, 45) Me.SelectBody.TabIndex = 9 Me.SelectBody.Text = "Select Body" Me.SelectBody.UseVisualStyleBackColor = True ' 'SelectBodies ' Me.SelectBodies.Location = New System.Drawing.Point(193, 40) Me.SelectBodies.Name = "SelectBodies" Me.SelectBodies.Size = New System.Drawing.Size(114, 45) Me.SelectBodies.TabIndex = 10 Me.SelectBodies.Text = "Select Bodies" Me.SelectBodies.UseVisualStyleBackColor = True ' 'Form1 ' Me.AutoScaleDimensions = New System.Drawing.SizeF(8.0!, 16.0!) Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font Me.ClientSize = New System.Drawing.Size(319, 192) Me.Controls.Add(Me.SelectBodies) Me.Controls.Add(Me.SelectBody) Me.Controls.Add(Me.Button_OK) Me.Controls.Add(Me.Button_Cancel) Me.Name = "Form1" Me.StartPosition = System.Windows.Forms.FormStartPosition.CenterScreen Me.Text = "Add Attribute" Me.ResumeLayout(False) End Sub Friend WithEvents Timer1 As System.Windows.Forms.Timer Friend WithEvents Button_Cancel As System.Windows.Forms.Button Friend WithEvents Button_OK As System.Windows.Forms.Button Friend WithEvents SelectBody As System.Windows.Forms.Button Friend WithEvents SelectBodies As System.Windows.Forms.Button End ClassWhen I used "Select Body" or "Select Bodies" program started, I saw selection window and I couldn't select anything.
What I can do?
Best regard
Michał Nowak
However, if you are limited to running the code as a journal, all is not lost. You may be able to re-work the logic of the workflow to use the form to set the desired options, then close the form and pass control back to the Sub Main routine. I'll try to post a simple example, but it may not be today...
CODE
Option Strict Off Imports System Imports NXOpen Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() Dim theUI As UI = UI.GetUI() If IsNothing(theSession.Parts.Work) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Dim theForm As New Form1 theForm.ShowDialog() 'user is essentially locked out of NX until the form is closed If theForm.DialogResult = Windows.Forms.DialogResult.Cancel Then MsgBox("user pressed 'Cancel', exit journal") Return End If MsgBox("continue journal code in Sub Main()") Dim userSelectedObjects() As TaggedObject If SelectObjects("select one or more objects", userSelectedObjects) = Selection.Response.Cancel Then lw.WriteLine("object selection canceled") Return End If 'get the options that the user selected on the form 'the journal could perform different actions based on the options chosen lw.WriteLine("Options selected:") lw.WriteLine("Option 1: " & theForm.CheckBox1.Checked.ToString) lw.WriteLine("Option 2: " & theForm.CheckBox2.Checked.ToString) lw.WriteLine("Option 3: " & theForm.CheckBox3.Checked.ToString) lw.WriteLine("") lw.WriteLine(userSelectedObjects.Length.ToString & " object(s) selected") lw.Close() End Sub Function SelectObjects(prompt As String, ByRef selObj As TaggedObject()) As Selection.Response Dim theUI As UI = UI.GetUI Dim typeArray() As Selection.SelectionType = _ {Selection.SelectionType.All, _ Selection.SelectionType.Faces, _ Selection.SelectionType.Edges, _ Selection.SelectionType.Features} Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects( _ prompt, "Selection", _ Selection.SelectionScope.AnyInAssembly, _ False, typeArray, selObj) If resp = Selection.Response.ObjectSelected Or _ resp = Selection.Response.ObjectSelectedByName Or _ resp = Selection.Response.Ok Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function End Module '************************************************************************************************ Public Class Form1 Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load End Sub Private Sub Button2_Click(sender As System.Object, e As System.EventArgs) Handles Button2.Click Me.DialogResult = Windows.Forms.DialogResult.Cancel Me.Close() 'form is now closed, but not unloaded 'values from the form can still be accessed End Sub Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click Me.DialogResult = Windows.Forms.DialogResult.OK Me.Close() 'form is now closed, but not unloaded 'values from the form can still be accessed End Sub End Class '************************************************************************************************ <Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _ Partial Class Form1 Inherits System.Windows.Forms.Form 'Form overrides dispose to clean up the component list. <System.Diagnostics.DebuggerNonUserCode()> _ Protected Overrides Sub Dispose(ByVal disposing As Boolean) Try If disposing AndAlso components IsNot Nothing Then components.Dispose() End If Finally MyBase.Dispose(disposing) End Try End Sub 'Required by the Windows Form Designer Private components As System.ComponentModel.IContainer 'NOTE: The following procedure is required by the Windows Form Designer 'It can be modified using the Windows Form Designer. 'Do not modify it using the code editor. <System.Diagnostics.DebuggerStepThrough()> _ Private Sub InitializeComponent() Me.GroupBox1 = New System.Windows.Forms.GroupBox() Me.CheckBox3 = New System.Windows.Forms.CheckBox() Me.CheckBox2 = New System.Windows.Forms.CheckBox() Me.CheckBox1 = New System.Windows.Forms.CheckBox() Me.Button1 = New System.Windows.Forms.Button() Me.Button2 = New System.Windows.Forms.Button() Me.GroupBox1.SuspendLayout() Me.SuspendLayout() ' 'GroupBox1 ' Me.GroupBox1.Controls.Add(Me.CheckBox3) Me.GroupBox1.Controls.Add(Me.CheckBox2) Me.GroupBox1.Controls.Add(Me.CheckBox1) Me.GroupBox1.Location = New System.Drawing.Point(12, 26) Me.GroupBox1.Name = "GroupBox1" Me.GroupBox1.Size = New System.Drawing.Size(260, 118) Me.GroupBox1.TabIndex = 0 Me.GroupBox1.TabStop = False Me.GroupBox1.Text = "Generic Options" ' 'CheckBox3 ' Me.CheckBox3.AutoSize = True Me.CheckBox3.Location = New System.Drawing.Point(22, 76) Me.CheckBox3.Name = "CheckBox3" Me.CheckBox3.Size = New System.Drawing.Size(66, 17) Me.CheckBox3.TabIndex = 2 Me.CheckBox3.Text = "Option 3" Me.CheckBox3.UseVisualStyleBackColor = True ' 'CheckBox2 ' Me.CheckBox2.AutoSize = True Me.CheckBox2.Location = New System.Drawing.Point(22, 53) Me.CheckBox2.Name = "CheckBox2" Me.CheckBox2.Size = New System.Drawing.Size(66, 17) Me.CheckBox2.TabIndex = 1 Me.CheckBox2.Text = "Option 2" Me.CheckBox2.UseVisualStyleBackColor = True ' 'CheckBox1 ' Me.CheckBox1.AutoSize = True Me.CheckBox1.Location = New System.Drawing.Point(22, 30) Me.CheckBox1.Name = "CheckBox1" Me.CheckBox1.Size = New System.Drawing.Size(66, 17) Me.CheckBox1.TabIndex = 0 Me.CheckBox1.Text = "Option 1" Me.CheckBox1.UseVisualStyleBackColor = True ' 'Button1 ' Me.Button1.Location = New System.Drawing.Point(12, 165) Me.Button1.Name = "Button1" Me.Button1.Size = New System.Drawing.Size(84, 34) Me.Button1.TabIndex = 1 Me.Button1.Text = "Select Objects" Me.Button1.UseVisualStyleBackColor = True ' 'Button2 ' Me.Button2.DialogResult = System.Windows.Forms.DialogResult.Cancel Me.Button2.Location = New System.Drawing.Point(188, 165) Me.Button2.Name = "Button2" Me.Button2.Size = New System.Drawing.Size(84, 34) Me.Button2.TabIndex = 2 Me.Button2.Text = "Cancel" Me.Button2.UseVisualStyleBackColor = True ' 'Form1 ' Me.AcceptButton = Me.Button1 Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!) Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font Me.CancelButton = Me.Button2 Me.ClientSize = New System.Drawing.Size(284, 218) Me.Controls.Add(Me.Button2) Me.Controls.Add(Me.Button1) Me.Controls.Add(Me.GroupBox1) Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.Fixed3D Me.MaximizeBox = False Me.MinimizeBox = False Me.Name = "Form1" Me.Text = "Form1" Me.GroupBox1.ResumeLayout(False) Me.GroupBox1.PerformLayout() Me.ResumeLayout(False) End Sub Friend WithEvents GroupBox1 As System.Windows.Forms.GroupBox Friend WithEvents CheckBox3 As System.Windows.Forms.CheckBox Friend WithEvents CheckBox2 As System.Windows.Forms.CheckBox Friend WithEvents CheckBox1 As System.Windows.Forms.CheckBox Friend WithEvents Button1 As System.Windows.Forms.Button Friend WithEvents Button2 As System.Windows.Forms.Button End Classwww.nxjournaling.com
CODE
Option Strict Off Imports System Imports System.Collections.Generic Imports NXOpen Imports NXOpen.UF Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() Dim theUI As UI = UI.GetUI() If IsNothing(theSession.Parts.Work) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Dim theForm As New Form1 theForm.ShowDialog() If theForm.DialogResult = Windows.Forms.DialogResult.Cancel Then MsgBox("user pressed 'Cancel', exit journal") Return End If MsgBox("continue journal code in Sub Main()") Dim selectionMask() As Selection.MaskTriple = Nothing BuildSelectionMask(selectionMask, theForm.chkFaces.Checked, theForm.chkCurves.Checked) Dim userSelectedObjects() As TaggedObject = Nothing If SelectObjects(selectionMask, userSelectedObjects) = Selection.Response.Cancel Then lw.WriteLine("object selection canceled") Return End If lw.WriteLine("Options selected:") lw.WriteLine("Select Solids: " & theForm.chkSolids.Checked.ToString) lw.WriteLine("Select Faces: " & theForm.chkFaces.Checked.ToString) lw.WriteLine("Select Curves: " & theForm.chkCurves.Checked.ToString) lw.WriteLine("") lw.WriteLine(userSelectedObjects.Length.ToString & " object(s) selected") lw.Close() End Sub Function SelectObjects(ByVal selMask() As Selection.MaskTriple, ByRef selObj() As TaggedObject) As Selection.Response Dim theUI As UI = UI.GetUI Dim prompt As String = "Select Objects" Dim title As String = "Selection" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = _ Selection.SelectionAction.ClearAndEnableSpecific Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects( _ prompt, title, scope, selAction, _ includeFeatures, keepHighlighted, selMask, selObj) If resp = Selection.Response.Ok Then Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Sub BuildSelectionMask(ByRef maskArray() As Selection.MaskTriple, ByVal faces As Boolean, ByVal curves As Boolean) Dim theSelectionMasks As New List(Of Selection.MaskTriple) Dim newSelMask As Selection.MaskTriple With newSelMask .Type = UFConstants.UF_solid_type .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY End With theSelectionMasks.Add(newSelMask) If faces Then newSelMask.Type = UFConstants.UF_solid_type newSelMask.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_FACE theSelectionMasks.Add(newSelMask) End If If curves Then newSelMask.Type = UFConstants.UF_line_type newSelMask.Subtype = UFConstants.UF_line_normal_subtype theSelectionMasks.Add(newSelMask) newSelMask.Type = UFConstants.UF_circle_type newSelMask.Subtype = UFConstants.UF_all_subtype theSelectionMasks.Add(newSelMask) newSelMask.Type = UFConstants.UF_conic_type newSelMask.Subtype = UFConstants.UF_all_subtype theSelectionMasks.Add(newSelMask) newSelMask.Type = UFConstants.UF_spline_type newSelMask.Subtype = UFConstants.UF_all_subtype theSelectionMasks.Add(newSelMask) End If maskArray = theSelectionMasks.ToArray End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image when the NX session terminates GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination '----Other unload options------- 'Unloads the image immediately after execution within NX 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately 'Unloads the image explicitly, via an unload dialog 'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly '------------------------------- End Function End Module '************************************************************************************************ Public Class Form1 Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load End Sub Private Sub Button2_Click(sender As System.Object, e As System.EventArgs) Handles Button2.Click Me.DialogResult = Windows.Forms.DialogResult.Cancel Me.Close() End Sub Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click Me.DialogResult = Windows.Forms.DialogResult.OK Me.Close() End Sub End Class '************************************************************************************************ <Global.Microsoft.VisualBasic.CompilerServices.DesignerGenerated()> _ Partial Class Form1 Inherits System.Windows.Forms.Form 'Form overrides dispose to clean up the component list. <System.Diagnostics.DebuggerNonUserCode()> _ Protected Overrides Sub Dispose(ByVal disposing As Boolean) Try If disposing AndAlso components IsNot Nothing Then components.Dispose() End If Finally MyBase.Dispose(disposing) End Try End Sub 'Required by the Windows Form Designer Private components As System.ComponentModel.IContainer 'NOTE: The following procedure is required by the Windows Form Designer 'It can be modified using the Windows Form Designer. 'Do not modify it using the code editor. <System.Diagnostics.DebuggerStepThrough()> _ Private Sub InitializeComponent() Me.GroupBox1 = New System.Windows.Forms.GroupBox() Me.chkCurves = New System.Windows.Forms.CheckBox() Me.chkFaces = New System.Windows.Forms.CheckBox() Me.chkSolids = New System.Windows.Forms.CheckBox() Me.Button1 = New System.Windows.Forms.Button() Me.Button2 = New System.Windows.Forms.Button() Me.GroupBox1.SuspendLayout() Me.SuspendLayout() ' 'GroupBox1 ' Me.GroupBox1.Controls.Add(Me.chkCurves) Me.GroupBox1.Controls.Add(Me.chkFaces) Me.GroupBox1.Controls.Add(Me.chkSolids) Me.GroupBox1.Location = New System.Drawing.Point(12, 26) Me.GroupBox1.Name = "GroupBox1" Me.GroupBox1.Size = New System.Drawing.Size(260, 118) Me.GroupBox1.TabIndex = 0 Me.GroupBox1.TabStop = False Me.GroupBox1.Text = "Selection Options" ' 'chkCurves ' Me.chkCurves.AutoSize = True Me.chkCurves.Location = New System.Drawing.Point(22, 76) Me.chkCurves.Name = "chkCurves" Me.chkCurves.Size = New System.Drawing.Size(59, 17) Me.chkCurves.TabIndex = 2 Me.chkCurves.Text = "Curves" Me.chkCurves.UseVisualStyleBackColor = True ' 'chkFaces ' Me.chkFaces.AutoSize = True Me.chkFaces.Location = New System.Drawing.Point(22, 53) Me.chkFaces.Name = "chkFaces" Me.chkFaces.Size = New System.Drawing.Size(55, 17) Me.chkFaces.TabIndex = 1 Me.chkFaces.Text = "Faces" Me.chkFaces.UseVisualStyleBackColor = True ' 'chkSolids ' Me.chkSolids.AutoSize = True Me.chkSolids.Checked = True Me.chkSolids.CheckState = System.Windows.Forms.CheckState.Checked Me.chkSolids.Enabled = False Me.chkSolids.Location = New System.Drawing.Point(22, 30) Me.chkSolids.Name = "chkSolids" Me.chkSolids.Size = New System.Drawing.Size(54, 17) Me.chkSolids.TabIndex = 0 Me.chkSolids.Text = "Solids" Me.chkSolids.UseVisualStyleBackColor = True ' 'Button1 ' Me.Button1.Location = New System.Drawing.Point(12, 165) Me.Button1.Name = "Button1" Me.Button1.Size = New System.Drawing.Size(84, 34) Me.Button1.TabIndex = 1 Me.Button1.Text = "Select Objects" Me.Button1.UseVisualStyleBackColor = True ' 'Button2 ' Me.Button2.DialogResult = System.Windows.Forms.DialogResult.Cancel Me.Button2.Location = New System.Drawing.Point(188, 165) Me.Button2.Name = "Button2" Me.Button2.Size = New System.Drawing.Size(84, 34) Me.Button2.TabIndex = 2 Me.Button2.Text = "Cancel" Me.Button2.UseVisualStyleBackColor = True ' 'Form1 ' Me.AcceptButton = Me.Button1 Me.AutoScaleDimensions = New System.Drawing.SizeF(6.0!, 13.0!) Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font Me.CancelButton = Me.Button2 Me.ClientSize = New System.Drawing.Size(284, 218) Me.Controls.Add(Me.Button2) Me.Controls.Add(Me.Button1) Me.Controls.Add(Me.GroupBox1) Me.FormBorderStyle = System.Windows.Forms.FormBorderStyle.Fixed3D Me.MaximizeBox = False Me.MinimizeBox = False Me.Name = "Form1" Me.Text = "Form1" Me.GroupBox1.ResumeLayout(False) Me.GroupBox1.PerformLayout() Me.ResumeLayout(False) End Sub Friend WithEvents GroupBox1 As System.Windows.Forms.GroupBox Friend WithEvents chkCurves As System.Windows.Forms.CheckBox Friend WithEvents chkFaces As System.Windows.Forms.CheckBox Friend WithEvents chkSolids As System.Windows.Forms.CheckBox Friend WithEvents Button1 As System.Windows.Forms.Button Friend WithEvents Button2 As System.Windows.Forms.Button End Classwww.nxjournaling.com
Last week I was sick and I couldn't work with this.
I pay tribute to your solution
Best regards
Michał Nowak
Can you make a similar example but with MODELESS?
I have the NX AUTHOR LICENSE and I can compile it.
CAD NX9 Electrical Designer / NXOpen
Product Design Analyst
MSXI / LEAR Sao Paulo Brasil
Masters Degree Math, Wayne State Univ
