frequency variation with increasing load
Hey guys
I'm trying to perform a simulation in Matlab/Simulink to see the frequency variation with a load increase. I'm putting a AC voltage source behind a RL impedance with a PI model of the line. The first load is a RLC parallel load with P= 6kW Ql=1000 var and Qc=-1000 var. The second load is actived 3 seconds later to see the difference. This second load is the same the first one. I was expecting a sustained sub frequency as it happens in real power systems. But the frequency makes a fast variation and gets back to the previous value of 60 Hz. Is my simulation wrong, or is my concept wrong?
I'm sending the file that has been made using Matlab version 2013a.
RE: frequency variation with increasing load
Gunnar Englund
www.gke.org
Yes, David said so, too.
Gunnar Englund
www.gke.org
f-f0 =-k(P-P0).
And plug into the voltage source the difference in frequency associated with the additional load. What do you think?
