Free standing Stair
Free standing Stair
hello everbody
i need to design a free standing stair for the first time anybody can help me please ??
RE: Free standing Stair
That response should make just about the same amount of sense as your post.
More seriously, What country? What rules? What Codes? What material? What does the architect want? What does your boss want?
Mike McCann, PE, SE (WA)
If you mean "free floating", there are many ways to accomplish that depending on materials, span, appearances, etc.
3 landing
One starts from ground up to 1 m
2nd goes from 1 m to 3m level
The last goes to first floor
Supported on on founation and the first floor
Height is 4m
No columns
Width is 1.4 m
Or
Cantilever landing from foundation to level 1
And another cantilever from first floor to level 2
These cantilevers carring the mid landing
I did a similar stairs years ago where I cantilevered the first stair run out of the basement slab with a thickened foundation. You can also cantilever the other runs (down and up) out from the intermediate floors with the landing connecting the ends of the cantilever runs. Make sure you control deflections and vibrations.
I seem to recall that the cantilevered stairs between floors at Peachtree Plaza had a concrete handrail around the outside which provided considerable stiffness.
It is just a matter of detailing it properly. If it is your first ornamental stair design, you should have a senior engineer reviewing and approving of your design work. Since the reinforcing is critical, I also recommend on site inspection of reinforcing before pouring any concrete.
A sketch would help us understand your problem.
Sketch out the forces at the landing to staircase interface. They are fun! Also, you cannot get away very thin in this case and actually support the floor loadings a staircase is normally required to handle.
Possible, challenging, and not for the faint of heart. Also, you really must charge appropriately; I charged five times my normal hourly rate, and I was only *just* happy... Liability like mad!
