Jornal: Load(read) all materials from material library
Hey!
I write a journal to add attributes and material to every component in assembly.
In this journal I have combobox with material.
My idea is add all materials from material library to this Combobox.
I can't find way to read material from library.
Maybe somebody know what I must doing.
Best regards
Michał Nowak
NX9 & Tc10
RE: Jornal: Load(read) all materials from material library
Learn to read .xml files via VB - the material library is an .xml file!
Thanks daluigi, it works.
I still thought - what I must doing for do it with NX.
If anyone ever going to need this I wrote this code:
CODE --> vb
Imports System.Xml
Imports System.IO
Dim material_File as String
Dim IS_Material_File as Boolean = False
If(File.Exists(UGIIROOTDIR & "physicalmateriallibrary.xml")) Then
	material_File = UGIIROOTDIR & "physicalmateriallibrary.xml"
	IS_Material_File = True
Else
	Msgbox ("I have no blade pojecie gdzie jest baza materiałów")
End if
     If Is_Material_File = true then
        Dim xmldoc As New XmlDocument()
        Dim xmlnode As XmlNodeList
        Dim i As Integer
        Dim str As String
        Dim fs As New FileStream(material_File, FileMode.Open, FileAccess.Read)
        xmldoc.Load(fs)
        xmlnode = xmldoc.SelectNodes("//Material/BulkDetails")
		lw.Writeline(xmlnode.Count)
        For i = 0 To xmlnode.Count - 1
            str = xmlnode(i).ChildNodes.Item(0).InnerText.Trim()
            myDialog.ComboBox1.Items.Add(str)
        Next
     End If
Best regards
Michał Nowak
