Using Check Sum Forces in API
Hey folks!
I'm attempting to use the Check Sum Forces tool in my API script. I'm a bit of rookie writing VBA but I have a little experience--but I have no experience writing VBA in the FEMAP API (as my pasted code probably shows). The goal of the script is to prompt the user to select a range of node IDs and have the Check Sum Forces tool sum the forces of the nodes around the global rectangular origin. I can't seem to get the feCheckSumForces2 command to work, I keep receive the error " Expecting '(' " for that line. Here is my code:
Sub Main
Dim model1 As femap.model
Dim set1 As femap.Set
Dim node1 As femap.Node
Set model1 = GetObject(,"femap.model")
Set set1 = model1.feSet
Set node1 = model1.feNode
set1.Select(FT_NODE,True,"Select Node(s)")
Do While set1.Next
node1.Get(set1.CurrentID)
Loop
Dim origin(2) As Long
Dim checkParam(3) As Boolean
origin(0) = 0 : origin(1) = 0: origin(2) = 0
checkParam(0) = False : checkParam(1) = False : checkParam(2) = True : checkParam(3) = True
Dim checkoutput(26) As femap.OutputSet
checkoutput.feCheckSumForces2(checkParam, set1, 0, 0, origin, 0)
End Sub
And for convenience, here is the help page on feCheckSumForces2 :
3.5.6.17 feCheckSumForces2
feCheckSumForces2
( useBodyLoad, expandGEOM, doLIST, useSETS, nodeSET, elemSET, loaddefSET, basePOINT, csysID, summedFORCES )
Description:
This function checks loads from the active load set and sums the forces around a specific location.
Input:
BOOL useBodyLoad
If True, body loads will be included in the calculation. If not, body loads will be ignored
BOOL expandGEOM
If True, geometric loads are expanded before the check. If not, nonexpanded geometric loads will be ignored.
BOOL doLIST
If True, a summary report is written.
BOOL useSETS
If True, nodeSET and elemSET OR loaddefSET must specify the nodes and elements OR load definitions to consider in the summation. To use nodeSET and elemSET, set loaddefSET = 0, otherwise, loaddefSET will be used. If False, the full model is used.
INT4 nodeSET
The ID of a selection set that contains the IDs of the nodes to check. Alternatively, if you specify a negative value, this is simply the ID of the single node to check. Only used if useSETS=True and loaddefSET = 0
INT4 elemSET
The ID of a selection set that contains the IDs of the elements to check. Alternatively, if you specify a negative value, this is simply the ID of the single element to check. Only used if useSETS=True and loaddefSET = 0.
INT4 loaddefSET
The ID of a selection set that contains the IDs of the load definitions to check. Alternatively, if you specify a negative value, this is simply the ID of the single load definition. Only used if useSETS=True.
REAL8 basePOINT[0..2]
The coordinates of the location to sum about. Must be in global rectangular coordinates.
INT4 csysID
The coordinate system used to report and returned the summed loads.
Output:
REAL8 summedFORCES[0..26]
The results of the force summation. Entries [0..5] are the nodal force summations. [6..8] contain the elemental force summation. [9..14] contain the total summation. [15-17] contain body translational acceleration. [18-20] contain body varying translational acceleration. [21-23] contain body rotational acceleration. [24-26] contain body rotational velocity.
Sub Main
Do While set1.Next
Loop
End Sub
feCheckSumForces2
Description:
Input:
BOOL useBodyLoad
BOOL expandGEOM
BOOL doLIST
BOOL useSETS
INT4 nodeSET
INT4 elemSET
INT4 loaddefSET
INT4 csysID
Output:
RE: Using Check Sum Forces in API
Hmmm yes a few mistakes in your code:
"Dim checkoutput(26) As femap.OutputSet" won't do, you can't dimension an outputset object (or at least i don't think you can), I doubt VB6 will allow you to turn an objet into an array
Next the method you use belongs to the "femap.model" object, not the outputset object
Then when VB6 expects values it refuses arrays. so your "checkparam" array won't do
Then the method you use sums loads, not NASTRAN output forces, not sure this is what you had in mind...
Here's a cleaned version of you code, but you need to clarify exactly what you want to do
AP
Sub Main
Dim App As femap.model
Set App = feFemap()
Dim v1 As Variant
Set set1 = App.feSet
If set1.Select(FT_NODE,True,"Select Node(s)") = FE_CANCEL Then End
App.feCheckSumForces2(False,False,True,True,set1.ID,0,0,origin,0,v1)
End Sub
I was able to get it running after my initial post. After working with someone in the office I saw how many obvious mistakes I was making! Anyway, I can get the Check Sum Forces tool to run now but not in the manner I was hoping to use it. Yes, I am simply trying to sum the forces applied on the nodes, not the resultant loads/stresses from those forces. However, I need to run through the range of nodes "backwards" in an increasingly cumalative way. For instance, let's say that I selected nodes 301 through 305 (five nodes) in set1. I would want to first sum just the last node (305) about its coordinates, then I would want to sum the last two nodes (304 & 305) about 304's coordinates, then I would want to sum the last three nodes (303, 304, & 305) about 303's coordinates, and so on.
I was hoping I could simply select the range as 305 to 301 instead of 301 to 305 to get set1 formatted the right way but it won't let me do that. I realize I then need to create another set that somehow collects the nodes from set1 "backwards".
Does what I am trying to accomplish make sense?
Updated code:
Sub Main
Dim coord(3) As Variant
set1.ID = 1
Do While set1.Next
Loop
Dim length As Double
length = set1.Count
coord(0)=node1.x
coord(1)=node1.y
coord(2)=node1.z
Dim checkoutput As Variant
model1.feCheckSumForces2(False,False,True,True, set1.ID, 0, 0, coord, 0,checkoutput)
End Sub
Dim set1 As femap.SortSet
Set set1 = App.feSort
If set1.Select(FT_NODE,False,"Select nodes") = FE_CANCEL Then End
The rest of your code doesn't make much sense I'm afraid.
Your loop is closed by the "Loop" statement, therefore it is not properly placed. Your "length" has no use. Perhaps what you're looking for is something like:
While set1.Next
model1.feCoordOnNode(set1.CurrentID,coord)
Wend
But the problem with this is that it won't really work with th efact that you want to group certain nodes for summation.
You could insert an If statement but that would be tedious and not generic.
The best way to structure your code (from what I understand) might be this:
While the user doesn't press cancel
i.e:
Set App = feFemap()
Dim v1 As Variant
Dim coord() As Double, checkoutput(2) As Double
While set1.Select(FT_NODE,False,"Select nodes") <> FE_CANCEL
set1.Reset
ReDim coord(2)
While set1.Next
App.feCoordOnNode(set1.Current,v1)
For i = 0 To 2
coord(i) =coord(i)+v1(i)
Next
Wend
For i = 0 To 2
coord(i) =coord(i)/set1.Count
Next
model1.feCheckSumForces2(False,False,True,True,set1.ID,0,0,coord, 0,v1)
For i = 0 To 2
checkoutput(0) =checkoutput(0)+v1(0)
Next
Wend
This will returns the next higher ID after the specified starting ID (nstartID).
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac û France
set1.Reset
ReDim coord(2)
I could think of a few work-around methods to only select a specific range of load sets but does FEMAP really not have a more convenient way of doing that just like it allows me to do for node selection (bolded line of code below)?
Dim coord(2) As Variant
Dim set2 As femap.Set
Dim myExcel1 As Object
Dim loadSet1 As femap.LoadSet
Set myExcel1 = GetObject(, "Excel.Application")
Set set2 = model1.feSet
Set loadSet1 = model1.feLoadSet
set1.ID = 1
set2.ID = 2
loadSet1.Select(FT_LOAD_DIR, True, "Select Load Set(s)")
So:
set1.SelectMultiID(FT_LOAD_DIR,1,"Select LoadCases")
quick tip: take advatage of the fact that FEMAP suggests available functionnalities as you write in the API window. When writing my Code above, FEMAP proposed these methods when I wrote only "set1.sel":
Select
SelectID
SelectIDInSet
SelectList
SelectMultiID
SelectOutputVectorID
Then got the the API help to learn about all these different methods.
AP
