Dimission Associate
Dimission Associate
RE: Dimission Associate
Dimension leaders are always associated to an object, but the dimension text itself can also be associated to another object (useful for getting a dimension or note to move when a related item moves). If, after updating the leaders, the dimension still shows as 'retained' try dragging the dimension text to a new location (or using the "edit origin" command) to break the associativity to the other object.
www.nxjournaling.com
Thanks cowski.. I moved the dimension to a new location then moved back to the orignal loacation and it re associated...What an odd what to re associate
