Range thickness for WPS with PWHT
Dear Sir,
I have 1 PQR with thickness base metal 25mm, No require CVN, Have PWHT, Qualified follow ASME IX.
So i can develop 1 WSP with max range thickness 200mm with the same Temp and Holding time PWHT in this PQR.
RE: Range thickness for WPS with PWHT
For welding 200mm base metal you need a PQR done on a minimum of 1.5" thick base metal with deposited weld metal of each process of ¾" or more.
If you take a 1.5" thick base metal and weld it with 2 processes (¾" each), you will qualify for base metal of 5 to 200mm and deposited weld metal for each process of 200mm. Refer Table QW-451.1 of Section IX
