All files getting saved instead of only changed files
After converting an assembly from NX into Creo, I am keeping that assembly in its own folder structure. When I am ready, I copy the files from the folder to a single directory where all my files will end up. Then when I create a new assembly file in with the single directory of parts that I copied over and assemble the files, I save the assembly file, but it always wants to save every file in the assembly instead of just the assembly file, even though nothing has changed about the files that I copied over. Is there something that I am missing?
It was suggested that I put "save_objects changed" into my config.pro, but that has not seemed to of done anything.
Any help would be greatly appreciated.
RE: All files getting saved instead of only changed files
Just like NX, Creo will update the file structure to the latest version when a file is opened. These files will be marked as modified.
Have you created relationships between the parts in the assembly file that may be driving the changes?
Ben Loosli
I place certain commands in there that I do not want my users to change, like the default_web_browser being set to my Windchill system.
Ben Loosli
