thread561-348324 Inspection points using PMI (Coordinate Notes)
I was looking at an old post that talked about extracting associative X, Y and Z valued expressions inspection points> It said "This will be improved in NX 9.0 with the advent of the 'Measure Point' function which will let you extract associative X, Y and Z valued expressions from any Point in your model, including when working in an Assembly."
We currently are using NX9 and I tried to use the 'measure point' function, but I can only get it to work for one point at a time. Is there a way to select multiple points and get a report you can put in a table?
RE: thread561-348324 Inspection points using PMI (Coordinate Notes)
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks, that is what I am looking for. I will give it a try.
I ran the Grip and it gave me a few errors, not sure if it is operator error. I had a couple of other guys try it and we get the following errors:
1) Error 1545021 at line 41 in Pts_to_txt-file.
the string is too long. Check the variable declarations or the command limitations.
2) Error 1545031 at line 45 in Pts_to_txt-file.
the character position in the string is invalid.
After this error the window popped up and I was able to select the points. then the following error popped up.
3) Data file Saving Error! Program Terminating!
Any help would be greatly appreciated.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I am still getting and error and it will not save the data. The error is:
Error 1545031 at line 47 in Pts_to_txt-file.
I am running NX 9 with Teamcenter. Not sure if Teamcenter makes a difference.
Any help on this would be greatly appreciated.
Thank-You.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
