Re-program Cummins PCC 3201 Controller
I currently have a Cummins PCC 3201 controller that I need to re-flash for 60HZ (currently is programmed for 50Hz) do I need to have Incal current to update the checksums/feature codes for 60Hz? What exactly is contained inside the "PGA" folder, do I need to remove this folder and update it with something else? I'm currently using Inpower 10.0
