Max Load on Composite deck
Hi All
I have to design a composite mezzanine slab in a factory setting. The max load is around 520 lb/sq.ft (approx. 3.62 psi/25kN/m^2).
I am aware that as per BS, for such heavy loads the metal deck is considered as a permanent shuttering and only the concrete slab is considered designed to span between beams
Does AISC have any loads beyond which composite action is not to be considered? Any references will definitely help.
rags
rags
RE: Max Load on Composite deck
