Vertical tab in a Windows OS window
I'm running my program from a windowsOS command line window and outputting data and character strings to the same window.
I can write non-advancing output and overwrite the same line via backspaces and writing again (on the same line).
Is it possible, with Fortran, to do an upward vertical tab and overwrite the line above, in a windowsOS command line window?
Thank you.
RE: Vertical tab in a Windows OS window
If you're running XP, it will work on command.com provided ansi.sys is loaded (you need to change config.nt). It doesn't work on cmd.exe. Just make sure that the height of "Window Size" and "Screen buffer size" are the same. Alternatively there are some windows routines to move the cursor to any point on the screen.
Thank you.
Regarding Alternatively there are some windows routines to move the cursor to any point on the screen.
To get me started, what are the names of these windows routines?
Are they in the form of a dll requiring a multilanguage call from Fortran to C++ via interface statements?
Which development system are you using (Silverfrost, Intel, gcc etc)? The routine names vary.
They are normally multilanguage but dev systems like Intel already have the interfaces: all you need to do is call them. I may even be able to give you an example but I have to know what development system you're using.
gcc please, via make files.
Sorry - no makefile. I don't use make on windows. To build
CODE
gfortran -g -o cursorg.exe cursorg.f90
The following puts a message at 40,10 on the screen
CODE --> cursorg.f90
module winconsole
   use, intrinsic:: ISO_C_BINDING
   type, bind(C):: COORD
      integer(C_SHORT) X
      integer(C_SHORT) Y
   end type  COORD
   integer (C_LONG), parameter:: STD_INPUT_HANDLE = -10
   integer (C_LONG), parameter:: STD_OUTPUT_HANDLE = -11
   integer (C_LONG), parameter:: STD_ERROR_HANDLE = -12
   interface
      function GetStdHandle(nStdHandle) &
         bind (C, name='GetStdHandle')
         import
         !GCC$ attributes dllexport, stdcall :: GetStdHandle
         integer (C_INTPTR_T) GetStdHandle
         integer (C_LONG), value:: nStdHandle
      end function GetStdHandle
      function SetConsoleCursorPosition (hConsoleOutput, dwCursorPosition ) &
         bind (C, name='SetConsoleCursorPosition')
         import
         !GCC$ attributes dllexport, stdcall :: SetConsoleCursorPosition
         integer(C_INT) SetConsoleCursorPosition
         integer(C_INT), value:: hConsoleOutput
         type(COORD), value:: dwCursorPosition
      end function SetConsoleCursorPosition
      function  WriteFile (hConsoleOutput ,lpCharacter ,nLength , lpNumberOfCharsWritten, overlapped ) &
         bind (C, name='WriteFile')
         import
         !GCC$ attributes dllexport, stdcall :: WriteFile
         integer (C_INT) WriteFile
         integer (C_INT), value:: hConsoleOutput
         character(kind=C_CHAR):: lpCharacter(1)
         integer (C_INT), value:: nLength
         integer (C_INT) lpNumberOfCharsWritten
         integer (C_INT) overlapped
      end function WriteFile
      function GetLastError() bind(C, name='GetLastError')
         import
         !GCC$ attributes dllexport, stdcall:: GetLastError
         integer (C_INT) GetLastError
      end function GetLastError
   end interface
contains
end module winconsole
program cursorg
   use, intrinsic :: ISO_C_BINDING
   use winconsole
   integer(C_LONG):: ires, written, leng
   integer(C_INTPTR_T):: hout
   type(COORD) posn
   integer, parameter:: TITLE_LEN = 80
   character(len=TITLE_LEN):: str
   hout = GetStdHandle(STD_OUTPUT_HANDLE)
   if (hout .eq. -1) then
      ires = GetLastError()
      print *, ires
      stop
   end if
   posn%x = 40
   posn%y = 10
   str = 'Hey it works'
   ires = SetConsoleCursorPosition(hout, posn)
   leng = len_trim(str)
   ires = WriteFile(hout, str, leng, written, 0)
   read (*,*) str
end program
This will need kernel32.a which can be obtained from the gcc website. The cmd prompt needs to have the same number of lines in the screen buffer and the window.
Great, thank you, I'll check it out.
