Two story concrete deck
I'm trying to design a two story concrete deck. I was wondering if there is a way to model one story and obtain all the final loads and automatically apply it the lower story using SAFE.
RE: Two story concrete deck
I've personally never tried to export loads from SAFE, so I can't comment on that question directly.
An alternative would be to model the entire structure in ETABS, which will then give you the option to export loads at each floor to import directly into each individual SAFE model.
