analysis-simple interference and Information-Part-Part History
In NX9, I would like to add analysis-simple interference and Information-Part-Part History (or the equivalent) to the ribbon or side bars.
I have not been able to find them,using Command Finder, anywhere but on the dropdown Menu. any thoughts?
RE: analysis-simple interference and Information-Part-Part History
You can then open the menu to find the commands you want and holding CTRL, you can drag & drop them onto the ribbon.
Otherwise, see the attached image for where in the customise menu you can find the commands.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
Do you know if these will go away when the Menu drop down goes away in NX11? I wouldn't think so but...
Anthony Galante
Anthony Galante
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I believe there was a miscommunication/misunderstanding between "classic Menus" and "Menu" when we were being update trained. :)
Thanks!
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
