Edit Angle Dimension Text Position in NX10
How do one place the text of an angle dimension to the left side of dimension lines?
By default, it is always positioned on right side whenever I add the angle dimension on drafting.
It seems to be not able to edit and place it on right side of dimension lines. See attached screen shot.
Anyone knows the workaround?
Thanks in advance.
BW
RE: Edit Angle Dimension Text Position in NX10
Try RMB the dimension, select 'Settings' and you can then set the stub side (see image).
Keep in mind that if you want to move the dimension, hold the CTRL key down before trying to drag it, otherwise the stub will swap back.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
Thanks Anthony.
Somehow I missed that setting.
