NX 8.5 Fit without Zoom
I have an assy including 3 parts , the difference is only length.
When i click "fit" in assy 3 of them "on" , the parts centered and fitted to the screen.
I turn off the other parts leaving the smallest part, then i click "fit" , NX centers and zooms to the part.
I only want centering option. I export images of the parts, if i do it like that. Smallest parts seems to be the biggest one because of zooming option.
RE: NX 8.5 Fit without Zoom
Try View-Operation-Fit view to selection.
Mathi K
View -> Operation -> Origin...
...and then select a point-of-interest that you would like the image to be centered-on.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Indeed it helped me but it is not what i want. I wanted one click to fit the part to center of the screen without zooming.
I used "pan" to move parts with same zooming % but i couldn't place them at the center of the screen. With your tip i can place origin at the center of the parts (not screen) but it is useful.
1) View - Operation - Zoom... Copy the zoom factor ( the value) Or use some other command which records the zoom factor)
2) Fit the view.
3) View - Operation - Zoom... Paste the last zoom factor value.
Tomas
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
So i guess that one can , by manual programming , read the current zoom , fit, and set to the previous zoom factor. But as John notes, the older zoom dialog doesn't "respond" to the Journal.
' NX 8.5.3.3
' Journal created by Tomas on Fri Jan 30 10:11:38 2015 W. Europe Standard Time
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
' Menu: View->Operation->Zoom...
' Menu: Fit
workPart.ModelingViews.WorkView.Fit()
workPart.ModelingViews.WorkView.SetScale(1.0087213953075)
' Menu: Tools->Journal->Stop Recording
End Sub
End Module
Tomas
CODE
www.nxjournaling.com
Tomas
