single hole or double hole lugs
I am seeing more customers asking for double hole lug connectors from cables to busbar connection.
what are the reasons for this? what are the advantages of double over single, and what are the disadvantages.
RE: single hole or double hole lugs
http://xternal.me
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
So, for the new turbine exciter, we have 4x 2 inch diameter leads that had to come vertically up through a 6 foot thick concrete floor. Then bend in a complex loop to be bolted horizontally to the copper plates on the exciter. The resulting "cable loops" in midair blocked access through the exciter equipment housing on that one side, so they needed an extra door in the housing. It was tight enough that to get room for the lowest of the cable loop, we "rounded off" the drilled holes in the concrete to be able to start the bends a little bit under the floor level.
