connection epoxy dowels
Dear All
I want to design of connection between concrete existing column and new concrete beam by epoxy dowels, can anybody help me in this issue.
RE: connection epoxy dowels
Second, define the problem;
How big a column?
How large a beam?
What shape beam?
How much load on the beam?
Moment only? Moment and shear? Shear only?
What application is your problem?
You have asked a question with no more detail than "I want to build a building. Can anybody help me?"
my question is general ,I need only the procedure of the check and design for example 1-check friction by equation ... 2-reinforcement use equation....@ACI318 and so on.
