Wye-Wye Neutral and Equipment Grounding
I would like to obtain everyone's comments on the transformer we perceived to be grounded.
The transformer is a 10 MVA 34.5 - 0.60 kV, Wye-wye with both primary and secondary neutrals grounded effectively. The primary supply side is also connected to a secondary Wye with neutral grounded. The secondary neutral is serving line-neutral loads.
We have used a dedicated return conductor from the transformer to the primary supply side. We used Equipment Grounding conductor to interconnect the equipment as shown...I would like to obtain anyone's comment in case we forgot something.
RE: Wye-Wye Neutral and Equipment Grounding
My doubt is how the SBJs (supply bonding jumpers) are connected at both primary and secondary wye points.
