Allowable Seal Leackage
I need help determining how much should be allowable seal leakage.
Seal oil to ambient
Oil Mil-PRF-23699 (5mm**2/s synthetic ester base stock) Kinematic Viscosity , @ 40 deg C cSt=25.26
Pressure 1800 psi
Seal Viton A, OD 5.395", ID 5.14"
Speed 1285 RPM
Balanced condition
Contact stress on seal 14.27 psi
Surface finish on sealing surface 16 micro inches
RE: Allowable Seal Leackage
I've only seen this information direct from the seal supplier or pump vendor. Too many variables for anyone to really give a response to this.
Even then the vendor will be reluctant, it should be given as approximate, not allowable. Nobody wants to handle a warranty claim for "excessive" seal leakage that turns out to be just slightly more than estimated.
waiting in Manf for a week
