pwht required for min. thickness
Dear All,
Base on which criteria to decide unasigne material required pwht equal or above minimum thickness.
i.e. cs required pwht equal or above 19mm thick and below not required as per asme 31.3
i have wp36 hsla steel which is unasigne in asme.
plz guide.
RE: pwht required for min. thickness
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
