China ToolKit to rename component
Is it possible to get "rename component" from the china toolkit ?
https://www.youtube.com/watch?v=0f9RQxvXjGc
Or does anybody have the same program ?
TIA
TIA
Didier Psaltopoulos
http://www.psi-cad.com
RE: China ToolKit to rename component
For more info read this post: http://www.eng-tips.com/viewthread.cfm?qid=362767
Using NX 8.0 and Teamcenter 8 on Windows 7 (64)
Didier Psaltopoulos
When i add this system variables the GC Toolkit works fine (except some company based settings that give problems when GC Toolkit is active. So i activate it only when i need to create a gear).
You would have to get access to the source code for the libgctool.dll that is used, or write code from scratch.
Anthony Galante
Senior Support Engineer
NX3 to NX10 with almost every MR (21versions)
