Jacketed Pipe Modeling
All of the work I do with PipePlus is double cointainment and vacuum jacketed piping.  Anyone has done this type of analysis with PipePlus? I always have to input the model using the spread sheet, "manually"! Is there a way of doing this with Supperdraw?  Anybody seen a book or paper about double containment piping?
Jalal
RE: Jacketed Pipe Modeling
The product information talks about jacketed pipe however I havent had need to use it. Suggest you browse the help section first. If you cant find what you are looking for then contact algor.
