Curve fitting using UF_MODL_create_fitted_spline with end slopes
I am trying to fit a curve using UF_MODL_create_fitted_spline providing end slopes. One end of the created spline shows a loop back due to the slope constraint. I have observed that NX decides the direction of the slope vector automatically. I tried negating the slope vector but still it causes a loop back. What causes this loop-back and what is the workaround for this?
I have 7 points for fitting with order 3. For a higher order 6, I see the loop-back getting reduced but the curve seems to be over constrained.
Data points -
P1: -1.560260,-0.181989,3.286604
P2: -1.578313,-0.213621,3.273950
P3: -1.595170,-0.242289,3.264351
P4: -1.596874,-0.276042,3.260926
P5: -1.572996,-0.298280,3.269681
P6: -1.542036,-0.306016,3.282902
P7: -1.509833,-0.310289,3.298223
Slopes -
Slope at beginning: 0.762061,0.552460,0.337714
Slope at end: 0.911118,0.097702,0.400398
RE: Curve fitting using UF_MODL_create_fitted_spline with end slopes
www.nxjournaling.com
CODE --> C++
// standard headers #include <iostream> #include <fstream> #include <string> #include <sstream> // #include <time.h> #include <stdio.h> // // #include <uf.h> #include <uf_ui.h> #include <uf_exit.h> #include <uf_defs.h> #include <uf_modl_curves.h> #include <uf_curve.h> #include <uf.h> #include <uf_csys.h> #include <uf_part.h> #include <uf_eval.h> #include <uf_forgeo.h> #include <uf_point.h> #include <uf_curve.h> #include <uf_modl_utilities.h> #include <uf_modl_freeform.h> #include <uf_modl.h> #include <uf_evalsf.h> #include <uf_defs.h> #include <uf_modl_types.h> using namespace std; int ReportError( char *file, int line, char *call, int irc) { if (irc) { char err[133]; char msg[256]; sprintf_s(msg, "ERROR code %d at line %d in %s:\n", irc, line, file); UF_get_fail_message(irc, err); sprintf_s(msg, "Error Message: %s\n",err); //std::string filstr(file); //stringstream ss; //ss << line; //string str_line = ss.str(); //sprintf_s(msg, "File : %s ... Line: %s\n",filstr, str_line); // create exception exception *ex = new exception(msg); throw ex; } return(irc); } #ifndef UF_CALL #define UF_CALL(X) (ReportError( __FILE__, __LINE__, #X, (X))) #endif int main(int argc, char* argv[]) { try { // Initialize NX UF_CALL(UF_initialize()); // ----- This code is for constructing part name string ----- // create a temporary part name time_t now = time(0); tm *ltm = localtime(&now); char l_cTimeStr[256]; // write to string sprintf_s(l_cTimeStr,"_%d%02d%02d_%02d%02d%02d",1900 + ltm->tm_year,1 + ltm->tm_mon,ltm->tm_mday, ltm->tm_hour, ltm->tm_min, ltm->tm_sec); // append to file name string partName = "BankFile"; int index = partName.find_last_of('.'); if (index>1) { partName = partName.substr(0,partName.size()-index+1); } int index1 = partName.find_last_of('\\'); int index2 = partName.find_last_of('/'); if (index1>index2) { partName = partName.substr(index1+1,partName.size()-index1); } else { partName = partName.substr(index2+1,partName.size()-index2); } // append the time stamp partName.append(l_cTimeStr); // Part tag tag_t m_tPartTagID; // Create part UF_CALL(UF_PART_new(partName.c_str(),2,&m_tPartTagID)); // Spline Curve Structure SPLINE_FIT_t tFitSplineData; double dMaxErr = 0.0; // Maximum err value double dTolerance = 0.001; // Default Tolerance value tag_t l_tSplineCrv = NULL_TAG; // Tag of the geometry bool bIsFeature = false; // Weight Data for the fit spline tFitSplineData.weights = NULL; tFitSplineData.num_of_weights = 0; tFitSplineData.weight_positions = NULL; // Segments Data tFitSplineData.num_of_segments = 0; // Tolerance always 0.0001 for all Airfoil curves tFitSplineData.tolerance = 0.001; // Degree of the fit spline tFitSplineData.degree = 3; // Point Data with its memory allocation tFitSplineData.num_of_points = 7; // error code int nErrorCode=0; // allocate memory tFitSplineData.points = (double*) malloc(3*(7)*sizeof(double)); // copy data to UF Array //P1: -1.560260,-0.181989,3.286604 //P2: -1.578313,-0.213621,3.273950 //P3: -1.595170,-0.242289,3.264351 //P4: -1.596874,-0.276042,3.260926 //P5: -1.572996,-0.298280,3.269681 //P6: -1.542036,-0.306016,3.282902 //P7: -1.509833,-0.310289,3.298223 int nPt = 0; //P1: -1.560260,-0.181989,3.286604 tFitSplineData.points[nPt] = -1.560260; nPt++; //1 tFitSplineData.points[nPt] = -0.181989; nPt++; tFitSplineData.points[nPt] = 3.286604; nPt++; //P2: -1.578313,-0.213621,3.273950 tFitSplineData.points[nPt] = -1.578313; nPt++; //2 tFitSplineData.points[nPt] = -0.213621; nPt++; tFitSplineData.points[nPt] = 3.273950; nPt++; //P3: -1.595170,-0.242289,3.264351 tFitSplineData.points[nPt] = -1.595170; nPt++; //3 tFitSplineData.points[nPt] = -0.242289; nPt++; tFitSplineData.points[nPt] = 3.264351; nPt++; //P4: -1.596874,-0.276042,3.260926 tFitSplineData.points[nPt] = -1.596874; nPt++; //4 tFitSplineData.points[nPt] = -0.276042; nPt++; tFitSplineData.points[nPt] = 3.260926; nPt++; // P5: -1.572996,-0.298280,3.269681 tFitSplineData.points[nPt] = -1.572996; nPt++;//5 tFitSplineData.points[nPt] = -0.298280; nPt++; tFitSplineData.points[nPt] = 3.269681; nPt++; //P6: -1.542036,-0.306016,3.282902 tFitSplineData.points[nPt] = -1.542036; nPt++;//6 tFitSplineData.points[nPt] = -0.306016; nPt++; tFitSplineData.points[nPt] = 3.282902; nPt++; //P7: -1.509833,-0.310289,3.298223 tFitSplineData.points[nPt] = -1.509833; nPt++;//7 tFitSplineData.points[nPt] = -0.310289; nPt++; tFitSplineData.points[nPt] = 3.298223; nPt++; // slope definition tFitSplineData.slope_flag = 3; // tFitSplineData.slopes = NULL; tFitSplineData.slopes = (double*) malloc(6*sizeof(double)); tFitSplineData.slopes[0]=0.762061; tFitSplineData.slopes[1]=0.552460; tFitSplineData.slopes[2]=0.337714; tFitSplineData.slopes[3]=0.911118; tFitSplineData.slopes[4]=0.097702; tFitSplineData.slopes[5]=0.400398; // Create Fit Spline with the above structure filled UF_CALL(UF_MODL_create_fitted_spline(&tFitSplineData, &dMaxErr, &nErrorCode, &l_tSplineCrv)); // Save part UF_CALL(UF_PART_save()); // close part UF_CALL(UF_PART_close(m_tPartTagID,1,1)); UF_CALL(UF_terminate()); } catch(exception e) { cout<<"An error occured. Please see the file ErrorLog.txt to see details."<<endl; cout<<e.what()<<endl; FILE* fptr; fptr = fopen("ErrorLog.txt","w"); fprintf(fptr,"\n\n"); fprintf(fptr,"An error occured\n"); fprintf(fptr,e.what()); fclose(fptr); } catch(exception *e) { cout<<"An error occured. Please see the file ErrorLog.txt to see details "<<endl; cout<<e->what()<<endl; FILE* fptr; fptr = fopen("ErrorLog.txt","w"); fprintf(fptr,"\n\n"); fprintf(fptr,"An error occured running MeshIC application\n"); fprintf(fptr,e->what()); fclose(fptr); } }RE: Curve fitting using UF_MODL_create_fitted_spline with end slopes
I ran your data with no slope control then the maximum error was 0.008 at point 4 (point numbers 1 to 7)
I then ran it using your end slopes and the maximum error was 0.0098 at point 2
Now the problem is that if you need to get a tighter tolerance and you increase say the order or the number of segments then the spline does the looping that you indicated.
Hope this helps
Frank Swinkels
