Design of high pitch (12:8 slope) light gage metal roof structure
3
My area (TX) has no seismic, but 90 mph wind area.
Light gage framing building, usually built as a pre-engineered building, requires engineering design this time.
Gable frames (25' span) and Z or C purlins will be used, but because of the roof slope, those purlins may require special bracing details due to eccentricity.
I looked up lots of metal companies, but couldn't find good product company and property table of their product.
Any recommendation for product company with design value table?
Thank you,
RE: Design of high pitch (12:8 slope) light gage metal roof structure
It will take some special care: almost more sideways force than lifting force?
What are the other sides? Winds will come from all 4 (8 ?) directions. What happens when it is end-on, or from the back of the building where other rotations or whirls will start tearing off sheetmetal?
ClarkDietrich is the largest supplier of light gauge steel framing.
http://www.clarkdietrich.com/
DaveAtkins
