need help with electric motor specs
220 volts 4000 rpms 12 amps
Are these the specs of an electric motor strong enough to propel an electric motorcycle ?
Help and recomendationtions greatly appreciated.
Thank you.
Thank you.
RE: need help with electric motor specs
Do you want it to keep up with traffic? Or is this one of those traffic-clogging e-bikes that can't get out of their own way?
je suis charlie
As BrianPetersen noted, 2.5kW is not enough power for anything except a "personal mobility device". But 220V is also sufficient to cause physical harm, so you would need to be very careful with this electrical circuit.
https://www.mrosupply.com/motors/ac-motors/general...
