Gap between annular plate and concrete foundation
Good morning Tank Builders,
We found there are 3 to 5 mm gap between the annular plate and concrete foundation outside the shell.
I believe we can not leave as it is.
What is the usual product that tank builders use to seal this gap ? Can we use non shrinkage grouting material or something like silicon ?
Thanks for the advise or advice :)
Syah
RE: Gap between annular plate and concrete foundation
"use non shrinkage grouting material "
Yes, that is the correct material. There really is no need for epoxy grout; my preference is cementious grout.
