Converter single phase to 3 phase
Is there any websites that show how to build a single phase/ three phase converter. to drive a 3 phase 5.5 hp motor for light wood cutting application. 220v incoming supply.
appreciated
sparks
appreciated
sparks
RE: Converter single phase to 3 phase
You can find some simple and cheap ways on site http://www.epanorama.net/links/motorcontrol.html
look at section "Using three phase motor on single phase supply.
B.r.
1. Build a single-phase rectifier, AC-DC single phase (approximately, 220VAC-300VDC)
2. Build or purchase DC-AC three-phase inverter (approximately, 300VDC-220VAC 3-phase). There may also be a 3-phase transformer 220V/380V added, if the motor uses 380V 3-phase voltage supply.
Search this site. The subject has been exhaustively discussed.
http://r.searchhippo.com/r3.php?i=3&q=roto+phase+generators&u=http%3A%2F%2Fwww.oceanmachinery.com%2Frotophase.htm
Just copy the whole thing to your URL window and enter.
