Flow in Pipes Q
Flow in Pipes Q
Hi lads, I'm a Mech eng student and I was wondering if you could help me out with the question in the attached picture:
-First of all I'm wondering why P2=0 because the question gives no indication that P1=150kPa is a gauge pressure
-I can understand why there is no head loss due to exit because point 2 is on the rim of the pipe just before exit but how come there is no head loss due to entry from the tank?
Thanks in advance for the help.
RE: Flow in Pipes Q
RE: Flow in Pipes Q
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
RE: Flow in Pipes Q
You are pumping from a pressurized tank to atmosphere
Atmosphere = 0 gauge pressure = 0 psig = 14.7 psia
The tank pressure is 150kPa psig
