Helpfull tip for anyone having trouble renaming files / folders in Windows Explorer
Do it in Solidworks Explorer.
Spent way too much time fighting the "folder can not be renamed because it is in use..." message, before thinking to try to do it this way.
Seems to be a common problem in Windows 7 and 8, and Microsoft is showing no interest in fixing it.
Now I've renamed a dozen folders in ten minutes versus fighting with it a whole day.
David
Connect with me on LinkedIn. http://lnkd.in/fY7-QK
Quote: "If it ain't broke, I must not've fixed it good enough"
RE: Helpfull tip for anyone having trouble renaming files / folders in Windows Explorer
you should post that in the FAQ area.
Kind regards,
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesGryphon Environmental
www.2gryphon.com
www.scottjbaugh.com
It's the only efficient way to do it. Using Windows Explorer is a PITA sometimes.
I agree with Scott, writing it up in the FAQ area is a good idea.
Chris, CSWA
SolidWorks 14
SolidWorks Legion
For Solidworks file, yes... We always rename in Solidworks.
These were our job folders, (just documentation, no Solidworks files) and we wanted to put a more little detail into the folder names to describe what the job was.
We've been putting it off because of the bug in windows, but I finally had a bit of downtime in to spend trying to figure it out.
Guess I could write up a short FAQ for it.
David
