Post weld heat treatment
Hello guys,
I am looking for post weld heat treatment process for Alum 6061 T6 aluminum weldment. I am talking about sizes of street light poles.
  • Procedure
  • Temperature requirements
  • Holding temperature
  • Equipement needed
  • Any quenching?
I am intending to bring the temper in the HAZ zone back to T6 after this heat treatment.
Any input is appreciated.
RE: Post weld heat treatment
Is the welding filler metal capable of achieving the strength of the 6061-T6?
I am not sure about this. But I know we use 4043.
4043 is not capable of meeting 6061-T6. So give up the idea of PWHT. You will simply need to size the materials/weld thickness to reflect the lower strength welds.
Thanks for your comments. I did read a little about this.
http://www.esab.ca/ca/en/education/blog/how-to-cho...
In the above link from ESAB it states that we need to use filler 4643 in case we are performing PWHT.
Now, I don't know what other changes should be involved in terms of welding equipment etc.
Also, this link says base material as ALUM 6061 T6, but in my case I am welding 6061 T6 extrusion to ALUM 356 casting. Not sure my case is different from what ESAB saying. I will also email their technical support & see what they have to say.
Further coming back to my original question, I believe (I could be wrong) that there is no liquid quenching involved in this PWHT. Just air cooling after 6hrs of holding at 360 deg F is sufficient. Any one know more information about this. or any study material/ resource would be appreciated.
